Good afternoon,
I am facing the error of being unable to install any office suite right now, due to a missing libsndfile.
The “nothing provides haiku>=r1-beta4_hrev56578_4-1 needed by libsndfile-1.1.0-3” error.
Pointers?
Good afternoon,
Pointers?
pkgman full in Terminal
Looks like you are using the repository for beta4, if you want to stay on beta3 you will have to update the repository url to the last state available for beta3.
beta4 will be released in a couple of werks in any case
Yeah, I’m not sure how that happened, as I installed Beta 3 explicitly. I’m still learning the system though.
Is this just a shortened form of ‘pkgman full-sync?’
Could you share the list of configured repos?
Yes. It may take a few though.
But, I may have accidentally got confused and wrote the nightly image to the usb drive.
Haiku base-url:
https://eu.hpkg.haiku-os.org/haiku/master/x86_64/current
identifier:
tag:haiku-os.org,2001:repositories/haiku/master/x86_64
priority: 1
HaikuPorts base-url:
https://eu.hpkg.haiku-os.org/haikuports/master/x86_64/current
identifier:
tag:haikuports.org,2013:repositories/haikuports/master/x86_64
priority: 1
yes
So, I did run that command, and then installed Libreoffice via pkgman.
And it works.
