What about the work on HaikuDepot? Some mistakes have not been improved or corrected since the beginning of the project.
- What you cant click around wildly, you quickly learn, because then completely spins the program window.
- The loading of the entries is extremely slow and you always do not
know whether the program still makes anything because no status is
displayed (Here would be a load window with bars advantage (or stackview)). - The search is more than insufficient. If you are looking for a certain program, you get everything possible but not nearly what you are looking for.
- Also, the search is extremely slow, the enter of search covers shame
the program full to its borders, so that all falls asleep. - If you are looking for a program from third, and would like to
install it then it can happen that the software is already on the haiku
server and is installed from there, even if the third-party version is
the most current. - You can not cancel the installation process
