I have an old revision of Haiku. Hrev45437, I believe. I can download and build that very version from within it, but only a “haiku-image” (raw) file. I can’t JAM a CD .iso, or Anyboot image. I’m wondering, what is (if anyone knows or can discover) the earliest revision of Haiku x86_64 from that point forward, that was able to JAM something other than only "haiku-image (raw)?
I think cdrtools is needed to build cd and anyboot profiles.
See https://git.haiku-os.org/haiku/tree/ReadMe.Compiling.md#n38
So it’s not incl. with nightly Haiku x86_64 images (Anyboot) that I download? The page you show above said all the tools needed are.
Indeed I’ll correct for you: “When building from Haiku, all of the necessary
development tools to build raw images are included in official releases (e.g. R1/alpha4) and in the
nightly builds.”
It says, and I quote: “When building from Haiku, all of the necessary
development tools are included in official releases (e.g. R1/alpha4) and in the
nightly builds”.
It says nothing about raw images only. Are you correcting (I assume) official information that is (now) incorrect? If so, then that information needs to be updated/corrected.
How do I install whatever software I need to JAM CD .ISO and Anyboot images? I mean, from within Haiku x86_64 hrev45437 or thereabouts?
