Hello to the comunity, new Haiku user here, I am want to just try the system from USB stick, but encounter some problems.
I have a Dell Latitude 110L laptop with ipw2915ABG wifi adapter. When I run R1/beta4 and doing “install-wifi-firmwares.sh” the adapter pop-ups in network settings as normal, but after I choose wifi access point and write a password - the window with SSID and password just reappear with error (can’t connect, possibly wrong password). Then I made the same things with R1/beta3, and the wifi works. Its disconects and reconects at random, but at least it works.
So, it seems the problem with R1/beta4, can it be fixed?
