cb88
1
Works on HP T5710 booted from USB. The system is a bit short on ram at 512MB - 32MB for the CMS but I am posting from it with Web+.
Not very fast probably on par with a P3 or slow P4. It has a bit better IO subsystem than those however as it has hypertransport.
The only think I had to do to get it to boot was enable failsafe video… otherwise the screen would get corrupted. Failsafe is really slow though.
I have a TC1000 but boot hangs on it will have to investigate further it would be a really neat device to have Haiku on though.
~/Desktop> sysinfo
Kernel name: kernel_x86 built on: Sep 22 2018 13:58:27 version 0x1
1 Transmeta Efficeon, revision 0f24 running at 1197MHz
CPU #0: "Transmeta Efficeon(tm) Processor TM8000"
Signature: 0x000f24; Features: 0x2fcff9ff
FPU VME DE PSE TSC MSR PAE MCE CX8 SEP MTRR PGE MCA CMOV PAT PSE36
PSN CFLUSH ACPI MMX FXSTR SSE SSE2 SS TM
Extended Features (0x00000001): 0x00000000
FCMOV
Inst TLB: 255 entries, 4-way set associative
Data TLB: 255 entries, 4-way set associative
L1 inst cache: 64 KB, 8-way set associative, 1 lines/tag, 32 bytes/line
L1 data cache: 128 KB, 4-way set associative, 1 lines/tag, 64 bytes/line
L2 cache: 1024 KB, 4-way set associative, 1 lines/tag, 128 bytes/line
Serial number: 2fcf-f9ff-0a01-92cb-2100-92cb
27570176 bytes free (used/max 483020800 / 510590976)
(cached 25460736)
61420 semaphores free (used/max 4116 / 65536)
3899 ports free (used/max 197 / 4096)
3941 threads free (used/max 155 / 4096)
2025 teams free (used/max 23 / 2048)
cb88
~/Desktop> listdev
device Serial bus controller (USB controller, EHCI) [c|3|20]
vendor 10b9: ULi Electronics Inc.
device 5239: USB 2.0 Controller
device Serial bus controller (USB controller, OHCI) [c|3|10]
device 5237: USB 1.1 Controller
device Mass storage controller (IDE interface) [1|1|fa]
device 5229: M5229 IDE
device Multimedia controller (Multimedia audio controller) [4|1|0]
device 5455: M5455 PCI AC-Link Controller Audio Device
device Bridge [6|80|0]
device 7101: M7101 Power Management Controller [PMU]
device 1563: M1563 HyperTransport South Bridge
vendor 1106: VIA Technologies, Inc.
device 3065: VT6102/VT6103 [Rhine-II]
device 5249: M5249 HTT to PCI Bridge
vendor 1002: Advanced Micro Devices, Inc. [AMD/ATI]
device 5159: RV100 [Radeon 7000 / Radeon VE]
vendor 1279: Transmeta Corporation
device 0061: TM8000 AGP bridge
device Bridge (Host bridge) [6|0|0]
device 0060: TM8000 Northbridge
~/Desktop> listusb
0430:0005 /dev/bus/usb/0/1 "Sun Microsystems, Inc." "Type 6 Keyboard" ver. 0102
0000:0000 /dev/bus/usb/0/hub "HAIKU Inc." "OHCI RootHub" ver. 0110
046d:c077 /dev/bus/usb/1/0 "Logitech, Inc." "M105 Optical Mouse" ver. 7200
0000:0000 /dev/bus/usb/1/hub "HAIKU Inc." "OHCI RootHub" ver. 0110
154b:00d4 /dev/bus/usb/2/0 "PNY" "USB 2.0 FD" ver. 0100
0000:0000 /dev/bus/usb/2/hub "HAIKU Inc." "EHCI RootHub" ver. 0200
~/Desktop>
