Hi everyone,
Haiku on a stick won’t write the latest anyboot nightly Haiku, it finished in 2 seconds, then when booting it said: Can’t find operating system. of course I injected the zip file and not the extracted .img file.
respectfully
Hi everyone,
respectfully
Yes i get problems too to make any boot image using Haiku on a Stick.
I think Haiku on a Stick is really old (date modified 11/2008 according to metadata in the version I have on disk; not sure if anything’s changed). That said, I’d recommend to use ImageWriter as an administrator if you’re running ReactOS/Windows or to use dd/dcfldd from a terminal as root on any other *nix-(like) platform for writing Anyboot images. Hope this helps.
