Hi,
I can’t install Haiku to hardware, because USB mouse does not work. I used two different Zotac Mini PC with USB3 and USB2, no mouse. I used a Shuttle XPC 3770 Series USB3 and USB3, no mouse. I used a Fujitsu PC (newer one) boot with kernel panic. The only way to use Haiku is Virtual Box. I did several changes in BIOS, but no change. I hope that this problem is solved in Beta 1.
Regards,
Bernd
