“There is no need to disable EFI boot” / “They used the wrong architecture in the emulation software, their issue was not caused by EFI”
I read again these sentences, but I’m not sure to understand anymore.
When I disable EFI on UTM for my MacBook Pro Intel it’s working fine, whereas it’s failing when EFI is enable. Is it possible to explain again in a few words ?
The problem in this thread was that they tried to emulate an ARM cpu, where they needed to emulate an amd64 (x86-64) cpu.
There are no bugs reported about efi beeing broken in qemu (or UTM), and their vm seemed to work fine from the screenshot above even before disabeling efi.
If this really is a problem for you then report it on the bug tracker please.
