Haiku in a Virtual Machine
I tried to run Haiku in a virtual machine, VMware, but it said I needed a 64 bit CPU, but my laptop has a 64 bit CPU and I couldn’t find any setting that would set the virtual CPU to 64 bit.
In the general options for the VM make sure you select “Other 64-bit” as the guest operating system type.
Ok. thank you :slight_smile:
got it working but when I burned Haiku to a USB thumb drive and skipped the install, it just behaved like it was installed and had persistence, but in the virtual machine, it acts like a CD and apparently I need to install it to something without erasing my real hard drives :thinking: When I try to install software from haiku depot, I get an error that some package or another couldn’t be downloaded. oh, and my VM is Oracle VIrtualBox.
If you boot the downloaded ISO file directly, that’s of course always read-only in VirtualBox.
You can create a virtual disk of the size you’d like, then boot the ISO again and use the Installer to install Haiku on your virtual disk.
When booting from the virtual disk afterwards, all settings and files should persist.
I got it working :slight_smile: but the screen looks a little squished. can’t find a resolution setting that matches my laptops resolution.
not sure what I did but after fiddling with the screen settings in haiku and then shutting down and restarting it later, the screen isn’t stretching out horizontally all the way to the edges of my laptop screen and now it doesn’t look squished.
do I need to reinstall every new build of Haiku or is it possible to upgrade haiku within the virtual machine to the latest nightly build?
If you have internet connection in your vm you can run software update, might need to adjust your repositories first to include nightlies. You can also do it from comma line using “pkgman full-sync” I believe
ok. thank you :slight_smile:
so this command will always update haiku to the latest build?
Yes I believe it will check all repositories and update any outdated files including os stuff.
You can find additional repositories that have additional programs to install that are not in the main haiku depot repository.
where do I find these repositories?
Here’s the site that lists third-party repositories:
But you’ll probably not need them,as most software is already available in the HaikuPorts repository that is enabled by default.
