Hello
I’ve got Haiku running on WinXP under Qemu, but I cannot get any sound for some reason. Is this a known issue, or can someone copy and paste me their working Qemu command? I think I have this issue in Linux as well, but I’m not there currently, but will update this post anon once I am.
Please advise if I need to post my machine specs.
My current command is:
REM Start qemu on windows. @ECHO OFF REM SDL_VIDEODRIVER=directx is faster than windib. But keyboard cannot work well. SET SDL_VIDEODRIVER=windib REM SDL_AUDIODRIVER=waveout or dsound can be used. Only if QEMU_AUDIO_DRV=sdl. SET SDL_AUDIODRIVER=dsound REM QEMU_AUDIO_DRV=dsound or fmod or sdl or none can be used. See qemu -audio-help. SET QEMU_AUDIO_DRV=sdl REM QEMU_AUDIO_LOG_TO_MONITOR=1 displays log messages in QEMU monitor. SET QEMU_AUDIO_LOG_TO_MONITOR=1 REM PCI-based PC(default): -M pc REM ISA-based PC : -M isapc REM -M isapc is added for NE2000 ISA card. REM qemu.exe -L . -m 1024 -kernel-kqemu -soundhw es1370 -net user -net nic,model=rtl8139 -hda haiku.img -localtime -M pc qemu.exe -L . -m 1024 qemu -soundhw all -net user -net nic -M pc -localtime -hda haiku.img
thanks in advance
