Hi,
I have an Athlon 64 PC with Geforece 6100 graphic card.
Where do I find a proper driver for the graphics for Haiku/BeOS 5 and how to install it?
Hi,
Haiku has built-in nvidia driver for old cards with GeForce 6100 covered.
But as I mentioned on IRC the driver has problems with this specific card, see
https://dev.haiku-os.org/ticket/2780 and https://dev.haiku-os.org/ticket/4670.
Geforce 6100 is onboard VGA, then probably it’s better to use Radeon HD 5570 (pci-e vga which I have too)?
I think I had tried Radeon HD 5570 on Haiku and the drivers work properly.
Speed-wise there should be no difference between VESA and radeon_hd driver.
I had tried Radeon HD 5570 on the Athlon 64 PC, but it doesn’t works (on that computer)… so onboard vga is for now.
