Haiku uses the “Debugger” command to Debug a program,however,i can find a gdb.
“Debugger” essentaily is gdb with a gui,and the gdb can be accessed via “Debugger -c”. The -c means command line mode. Here is my question, How can i make a (perminant) alias of “gdb=‘Debugger -c’”,this would allow debugging in Kdevelop
To make a gdb alias add
“alias gdb=‘Debugger -c’”
in
/boot/system/settings/etc/profile
It seems KDelevop cant access the ptty or tty to use the terminal
Debugger is not gdb, expect problems with the interoperability.
It is not at all gdb. It is a native Debugger with its own CLI commands. There is (or was?) a gdb in the package repo, but it is a very old one and won’t work properly for apps built with gcc7. Compiling a newer gdb is easy, but then it will not know how to plug into applications to debug things (we use a specific protocol for that, which is not the same as used elsewhere).
