If you package the interpreter, you can package the xmls files with it, so they can land in that folder.
Or you can create an own recipe for the xml files and make your program package depend on it, so it gets automatically selected and installed.
This actually might be something we should change in HaikuPorterās CMake scripts. Haiku packages can technically be installed in more than just /, though sometimes hardcoded paths make this difficult; we should try to improve this.
On a different note, it is always nice to see upstream developers enthusiastically embrace support for Haiku, so kudos to you ![]()
Great, thanks. I wasnāt sure if that was a protected system directory or not.
And the support here has been great. I appreciate all the help and explanations as Iām stumbling my way through things.
At this point I think itās purely a packaging thing. There was one issue where Iād given two major versions of one game system the same MIME type, but Iāve now got a pull request in to change it to separate types. If Haiku learns these MIME types, then it should be possible to properly assign MIME types to interpreters now.
Iām also adding file-type probing to the launcher. This will take precedence over extensions, though not all file types are able to be probed, so extensions will exist as a fallback. So the launcher should be more robust on systems like Haiku where extensions arenāt really used. Iāll have that in within a day or so.
Thanks for all the help, everybody. Itās late here, so Iām done for the day, but I think tomorrow Iāll have Gargoyleās source in a position where itās ready for a proper Haiku release. Then itāll be a matter of getting the recipe just right.
Haiku doesnāt actually need to learn the MIME types; you can ship definitions for them along with your application to be included as part of the system MIME database (at least this is theoretically supposed to work, but I donāt know how many applications actually do it.)
Iāve worked on a patch for the love2d recipe today to do just that, and it definetely is doable
I found the api Haiku has to make it do the work for you as an alternative, though this wonāt work with all file types always (haiku definetely canāt tell video/mp4 from audio/mo4 for example)
https://www.haiku-os.org/docs/api/Mime_8h.html
I think Iām missing something fundamental here. Iāve been able to add, programmatically, to the file type database with code similar to this:
BMimeType mime = BMimeType("application/x-blorb");
mime.Install();
mime.SetSnifferRule("0.5 ('FORM IFRS' & 0xffffffff00000000ffffffff)");
Tracker now shows Blorb files appropriately. However this has the obvious problem that it requires the app to run first, which is a chicken and egg problem (I mean, itās easy to fix by running it once, but thatās not the point). You guys are saying that definitions can be shipped, but Iām just not finding out how that works. Is it a file thatās just installed somewhere? I can write all the rules, but I donāt know where they go.
In short, I know there must be a way, non-programmatically, to specify MIME types + sniff rules as well as to specify which MIME types an application supports, but Iām just not following how thatās done on Haiku.
Yes, there is a way to specify this information via resource definition files. Here, for example, is the one for ODT files. These get compiled, then resattr'd, and then the resulting file is installed to the relevant mime_db directory (I donāt recall the precise mechanism for this however; it sounds like @nephele may?)
In the additional-files folder of the recipe you can add rdef definition files for new MIMEtypes
As an example (The one I worked on yesterday)
x-love-game.rdef
resource(0, "BEOS:TYPE") #'MIMS' "application/x-vnd.Be-meta-mime";
resource(1, "META:TYPE") "application/x-love-game";
resource(2, "META:S:DESC") #'MSDC' "LĆVE game";
resource(3, "META:L:DESC") #'MLDC' "A LĆVE based game archive";
resource(4, "META:PREF_APP") #'MSIG' "application/x-vnd.love";
resource(5, "META:ICON") #'VICN' array {
$"6E6369660403E74A9904004C0327AAE105FF040607FF1FC6D5B92DC6D5B92DC3"
$"E7B632BFB9B354C0A2B354BE55B354B382BF8BB382BE47B382C025B945C651B6"
$"52C358B982C62AB9F7C5CCB9BDC5FEBE5FC1A9C6D5B92DC38ABE34C6D5B92DB9"
$"2D0607FF1FC731B9B7C731B9B7C3E6BEBEBA53C655BEBBC233BA19C688B9A1C6"
$"DBB9DEC6B4BC6DC9AEC015CC4DBF57CC4DC1C3CC4DCC4DC015CC4DC130CC4DBF"
$"4DC731B9B7C9E5BC75C731B9B7B9B70607FF1FC6D5B92DC6D5B92DC38ABE34B9"
$"F7C5CCBE5FC1A9B9BDC5FEB945C651B982C62ABC11C925BFB9CBC3BEFBCBC3C1"
$"67CBC3CBF1BF8BCBF1C0A6CBF1BEC3C6D5B92DC989BBEBC6D5B92DB92D0608FE"
$"7FC01BBCBABCCABAE8BF08BA5FBA8CBB71BFC1C5B8B5DEC005BFC1C5B8BFBFC5"
$"B840C5B8C9A2C005C2B7BAE8C4F4BB71C079BA5FBF66BCBABF66BCBABFA2BCBA"
$"C01BBCBABFDFBCBAC01BBCBABCBA040A000100000A010101000A020102000A03"
$"010300"
You then need to compile this source file to a .rsrc file, either during the build or before it, personally I would do it beforehand and ship both the .rsrc and .rdef file since I consider that a bit more obvious
rc -o x-love-game.rsrc x-love-game.rdef
After you have compiled the ressource add it to the recipe as an additional entry under ADDITONAL_FILES so that the build can pick it up.
afterwards just add it to the mime_db during the build INSTALL phase like so:
# copy mimetype rsrc for love2d games
mkdir -p $dataDir/mime_db/application/
resattr -o $dataDir/mime_db/application/x-love-game $portDir/additional-files/x-love-game.rsrc
Basically: .rdef is the āsourceā text format for ressources, this gets compiled with rc, the ressource compiler, to a binary format and this then gets converted with resattr to a file that has all this information in different file attributes
I hope this was understandable, you can read more about rc here: Compile them resources | Haiku Project
You might also want to add sniffer rules to your mime type directly, I did not above because the love2d archive cannot be sniffed (Itās just a zip file), you can let yourself be inspired by other sniffer rules here: https://git.haiku-os.org/haiku/tree/src/data/mime_db (I donāt know the exact syntax either⦠Iāve only written the mp4 sniffer rule : D https://git.haiku-os.org/haiku/tree/src/data/mime_db/video/mp4 )
The only place where the syntax is currently documented is in Darkwyrmās āProgramming with Haikuā book series. We should add docs to api.haiku-os.org about it.
OK, thank you guys for the pointers to resources and packaging. Iāve hacked up an ugly script to convert freedesktop.org XML MIME files to something that Haiku might understand; the example resource files were a huge help. Itās available here.
Iāve included a few sample resource files it generated. rc seems to handle them fine, though I havenāt been able to actually test whether they match files properly. Itās also really hacky, including lack of support for more complex matching (e.g. if there are multiple possible rules), breakage if the magic string contains quotes (needs escaping), and just hacking around the fact that globs are supported by the fdo XML (special-casing *.z[1-8] for example). Itās enough to convert the stuff I need, though.
I think this is the best plan for the next release: Include these resource files (once theyāre verified as being good) with the Gargoyle source code; update the recipe to compile and install them; continue using custom probing in Gargoyle to handle files thrown at it; and associate MIME types with the launcher for the time being, not individual interpreters.
For the last point, I prefer maintaining status quo for the first Haiku-supported release; now that Iām getting more comfortable with Haiku development I can spend more time after the release improving things, but it looks like that will largely be recipe hacking, meaning updates to the recipe can happen in between Gargoyle releases.
A few people are working on HiDPI/Retina support for Gargoyle, and thatās the last roadblock, I think, before a real release. @nephele, is the recipe you created in a git branch somewhere? I can fork the appropriate repo to make contributing changes back to you easier before you get it into master (or whatever the appropriate release process is for ports).
It is not on a branch currently, I can make one if you would like, but I canāt submit it to haikuports directly since the workflow there is github pull requests and I lack a github account, so it might be faster if you submit it yourself : ).
