I am opening a new thread here, because this actually also is an important topic for me.
Is there a FORTRAN COMPILER for HAIKU ?
LLVM has Flang and GCC has its own Fortran frontend but I’ve not heard of either of them on Haiku.
Gfortran is in the depot. Why dont you install Haiku? You could easily get answer to most of your questions. Or use the search function at the depot website: https://depot.haiku-os.org/
Make sure the correct architecture is selected.
thanks for reply … i did install Haiku
