Finishing up extended partitions | Haiku Project
Aloha Haiku Land!
I have been putting the finishing touches on support for Extended Partitions today. For those of you who do not know the Master Boot Record or an MBR can only contain 4 primary partitions. This leaves something to be desired when you want to run a bunch of operating systems or split your install across multiple partitions. There is a way however to get as many partitions as you want however by creating what is called an Extended Partition.
This is a companion discussion topic for the original entry at https://www.haiku-os.org/blog/bebop/2009-08-14_finishing_extended_partitions/
