FAQ rework
Hello!
I’ve discovered Haiku only today and, after reading FAQ, I think it’s overloaded with unnecessary answers and structured badly.
  1. There are many answer that wouldn’t interest new people. Like the one about gcc2 or about tilde. Or in installation part — I think deep questions like ‘what to do in VirtualBox’ or ‘how to install from usb (isn’t it intuitive?’ belong to ‘Installation’ page whereas FAQ should be quick and easy to read.
  2. In my opinion, FAQ should answer the questions everyone asks. ‘What is Haiku?’, ‘How’s hardware support?’, ‘How is it different from Linux/Windows/etc?’, usability, that stuff. I think ‘Can I use Haiku as my primary…’ should come BEFORE ‘Are there other projects based on or inspired by BeOS?’. The same with hardware reqs - they should be in the beginning, not somewhere near the end of FAQ.
I could post my own version of FAQ (just reordered + removed some questions) if you wish.
Help is always welcome!
Thank you
The FAQ answers questions that are frequently asked. Even if they are not the ones you ask yourself. We can add more, but I don’t think there is much to remove?
I can see some merit in the idea of reordering it a bit? The suggestion to move much of the “Technical” section towards the end seems reasonable.
But I don’t see anything that calls out to be removed.
Perhaps I just understand FAQ differently. I think it’s more like ‘Never heard of Haiku? Great, read FAQ to get a quick overview’. In my opinion technical questions or installation guides don’t belong there. Something like ‘Haiku is built on a modular(?) kernel developed from ground-up. It features X, Y and Z’ would be enough. Two to three sentences so it’s quick to read. And deeper questions could be moved to a separate ‘Guides’ page or something like that.
Personally I don’t think that gcc2 or similar questions are more useful/helpful than ‘How can I contribute’, yet we don’t have that in FAQ. So it’d be only logical to cut out long stuff (to keep FAQ short) and include something more useful for newbies.
I’ll post my own vision of FAQ in a few hours.
“FAQ” means “Frequenly Asked Questions”. It contains answers to toe questions that are asked frequently. I don’t know what your definition is, and how it can be anything else than that?
Do people really ask ‘What is Kernel Debugging Land?’ or ‘Is there an instant messenger client?’ or ‘Where does the name Haiku come from?’ that frequently?
i mean, people would ask why gcc2 is being used in the 32bit versions. its because haiku 32 bit is beos compatible. otherwise we wouldnt have it at all
Here’s what I’ve got in ~15 minutes. Not perfect, of course. I’ve united all software questions under a single one + did the same with programming languages. Reordered and removed some.
∆ means rewrite the answer(or question)/add a new one.
Common Question
  • ∆ What is Haiku? + about 32- and 64-bit version
  • Is Haiku based on Linux?
  • Why not Linux?
  • Is Haiku then based on BeOS?
  • ∆ I’ve never seen Haiku. What does it look like? (attach photos directly!)
  • ∆ Can I use Haiku as my primary Operating System? + Can Haiku connect to the Internet + What is the status of wireless internet connections? (smth like 'Yes, you can use it as primary. You can connect to the Internet (inxluding wireless!), etc etc)
  • What license is Haiku released under?
  • What is Haiku Inc.?
  • What platform(s) is Haiku targeted to run on?
  • ∆ How can I contribute?
Package Management
  • Is there a package manager?
  • How do I update my installation of Haiku?
  • Where can I get more software for Haiku?
Applications
  • ∆ What programming languages are available on Haiku?
  • ∆ Are there any games/office suite/messengers/browser? (And answer as 'Yes! There’s LibreOffice, FireFox, etc.)
  • Will GoBe Productive work in Haiku?
Technical
  • When is the next release?
Hardware
  • What are the minimum hardware requirements to run Haiku?
  • Is there a list of working hardware?
  • Why doesn’t Haiku let me use my monitor’s resolution?
  • Is there multiple monitor support?
  • How come there is no sound?
  • Why is there no network access in VirtualBox?
Installing
  • Where can I get Haiku from?
  • How do I install to a USB stick?
Using
  • Why doesn’t the tilde key work properly?
  • How do I change my keyboard layout?
  • Is there some kind of failsafe mode I can boot into? How do I get to it?
People might ask that, yes, but I don’t think it’s a really frequent question. Not something people who just discovered Haiku should know about (people who know/contribute/want to contribute don’t read FAQ anyway because they know about the project and it’s technical details).
It doesn’t matter what you think. Sorry to put it bluntly.
It’s a frequent question, both here on the forum and also when we introduce Haiku at open source conferences. People try to compile something and find out the default corpiler is gcc 2. Or they just heard somewhere that Haiku is stuck with an old compiler and are confused about it, and wether it gets in the way of new developments.
no need for that first part. its kind of rude
Well, if you think so. But you could still reduce the amount of text in those answers. Just look:
I heard Haiku still uses gcc2, is that true?
Our own internal fork of gcc2 is used to compile the x86 32-bit release to maintain BeOS binary compatibility. While gcc2 is the primary compiler for the x86 32-bit release, it also includes a modern version of gcc (gcc13) which can be leveraged to compile newer applications requiring it.
Other architectures (including x86_64) don’t leverage gcc2.
Is there support for newer GCC compilers?
Yes! In order to provide support for a modern version of C++ and up to date libraries, the official versions of Haiku come with both gcc2 and gcc13 installed, and a set of libraries suitable for use with each compiler. If you are not interested in BeOS support, we also provide a 64-bit version of the system that uses only gcc13.
It repeats gcc13 twice. You could remove info about gcc13 from the first question and keep it simple (‘yes, it does because we keep Haiku compatible with BeOS. 64-bit version supports newer GCC compilers’). I mean, if someone is truly interested in GCC compilers in Haiku, they would read both questions.
Firstly, welcome to the community. It’s good to have new members eager to make a contribution so soon.
That said, before tackling something like FAQ’s and documentation I think it’s best to understand the community, the way Haiku functions as an OS and the development processes of Haiku first before suggesting changes to such documentation. A good example of a lack of understanding is your comment about the Kernel Debugging Land question in the FAQ. If you have used Haiku for any period of time would understand it is actually something important for new users to know about as it helps with the bug reporting and development process.
Some of your suggestions like reordering the FAQ sound good but I think it would be a good idea to spend a bit of time using Haiku and being involved with the community first to get an idea of what should be in the FAQ and other documentation.
Thank you for your answer!
Yes, I might’ve been too critical cutting out info about Kernel Debugging Land. What about moving it to ‘Usage’ instead since it’s directly linked to using Haiku?
maybe a debugging or programming category
also, gobe productive works on 32bit haiku
Perhaps, but the point stands: there are multiple ways to improve FAQ.
Some new user offers some specific help on a topic and it is great to have.
I am sure the Marketing Team will appericate it anyway.
GCC2 is the legacy compiler to maintain certain legacy BeOS software. Clarity on legacy compiler versus default compiler and CLI environment terminology for x86_gcc2 (as well as defining the x86_gcc2 versus “x86” environments).
Why not Linux? Linux is a kernel with hundreds of various distros with differing project idealogies, support systems, forums, and ecosystems. Many variants of the various build recipes of the same software in which the behavior of the software and provided software features may differ between the distros.
Etc, etc, etc…
Well done,
I like it, it covers old questions as well.
Most questions were from Haiku user itself, so not really new user.
This Q&A could be merged to the Site or for new Haiku user only.
We will see…
Help is always welcome.
