Hi, I can’t get Haiku (running from a USB flash drive into an Asus EEE 701 netbook) to display on my external monitor.
The only resolution available (from both booting without VGA connected, and with VGA connected) is 800x480 - the size of my laptop screen. Various versions of linux have had no problem displaying this resolution on my monitor, so I was wondering if there is a file I could edit within Haiku which would provide compatibility with my LCD. Something akin to Xorg.conf?
The LCD panel is can go up to 1680x1050 and I have tried 60Hz and 75Hz. Through each permutation of VGA plugged in on boot up, frequency change, and screen switching, the only results I get are “Out of range” or a garbled display of 800x480 (like the screen has been ‘slashed’ horizontally).
The netbook uses an Intel 910/915 chipset, and I am using the R1 alpha release.
Any help appreciated, thanks.
