Newbie to Haiku here. I have a question: How do I update this to the final build? Will it be seamless?
I remember being able to just manually install over the top nightly images before. I’m sure that remains possible, but can this update to Final within the OS? Maybe automatically? What about future releases?
Thanks, and sorry if this is the wrong place to post.
There is and has been for a long time, please read the user manual. @un_spacyar seems to have this configured properly.
It looks like the beta1 repos never got updated; the buildbot hasn’t been doing some builds automatically and we’ve had to kick it ourselves. I just did that; so hopefully -66+ will appear within an hour or so in the repos.
Thanks - both for your work, as well as for the correction.
I guess I was thrown off by:
That goes to show I should run more instances of Haiku
@un_spacyar:
I’m quite eager to find out as well whether Haiku will boot successfully with UEFI-only firmware. I’ve only got one piece of hardware, and it has no (functional) legacy mode.
Gpd win running EFI USB. Note that it loaded the VESA driver dispite being an intel chipset, and the device uses a tablet screen which you have to set to rotated otherwise it’s sideways, don’t know how to fix that on Haiku:
Wifi doesn’t work out of the box its Broadcom 4356 will try to build my own image with preinstalled wifi firmware and see how that goes.
touchscreen doesn’t work.
Mouse stick works as it emulates a USB mouse or an XBox or Joystick controller selectable by the switch in the middle of the device.
Keyboard works fine.
Didnt’ test sound.
