short question? Did somebody already tried to, or managed to port Eclipse IDE(https://eclipseide.org) to Haiku-OS?
I tried once, but did not succeed. I had a look at FreeBSD(ports) - how they did it. Was a good start. However, I failed in regard of a specific library usage.
Eclipse IDE is one of the best IDEs out there, so a port would be maybe nice also for others.
Netbeans has been updated this morning, on par with version 31 again. (remember this is still a _bin package, so grabbed from upstream as it always has been).
That’s not a sentence; it’s just a list. It doesn’t actually say what this list of version numbers is for or what it’s supposed to mean.
(The previous post I responded to was reported to the mods as being non-contributory because it didn’t actually say anything relevant; rather than just hiding your previous post, I’m asking what you mean because I expect that you did intend it to mean something but you’re not really helping with that.)
Read the previous posts. You need a SWT display backend or use GTK (and you need specific major/minor versions to work from). The list gives tell you GTK3 - not GTK2 or GTK4. Also, what is preferred by upstream for porting/development (OpenJDK 21) in which I mentioned JRE 17 is also supported as a bare minimum.
A porter shouldn’t start that journey without dealing with the basics or quickly fall into the Java rat nest of missing this or that. Guess I figured the person willing to do the work would know this somewhat… the depend versioning and listing the bare ingredients is kinda important… or maybe not…
