Drag a message with a designated BMessenger aka codename DropIt!
For the records, I have understood why this doesn’t and potentially can’t work.
It has nothing to do with any mutex or transaction, by the way.
When a file is dropped in-app, i.e. from one window to another (this also applies to the Desktop), the Tracker looks for the current selection in the source window and if the selection is empty it returns doing nothing.
Worse still it does not even check if the selection matches with the refs and just picks up the selected file from the source window ignoring the actual refs in the message.
This can be easily witnessed by manually changing the selection in the Tracker’s source window before dragging the “file” from DropIt! from fileA to fileB for example. You will end up with an unintended file being moved.
I am not sure if this could be considered a bug, in the end DropIt! wants to implement a quite uncommon and extreme use case. Nevertheless, I may be able to work this around by preprocessing the message and turning it into a “foreign drag” in Tracker’s term but looks a bit tricky.
All the more reason to get Haiku devs’ advice here.
EDIT: I may have changed my mind and would actually consider this as a design flaw. This unintended behaviour can be triggered at any time even without DropIt! in the middle.
It’s easy to reproduce it. Take two Tracker windows side by side pointing to folderA and folderB, respectively.
While dragging whatever element from windowA to windowB, close the former with the shortcut CMD-W. Now that it’s gone, keep dragging and drop the file onto the destination window and the Tracker will… do nothing.
EDIT2: Another scenario is as follows. If the selection is changed “in-flight” with the arrow keys the new currently selected element is moved to the destination. Bummer!
It looks like something that could be improved in Tracker.
Even if DropIt! tries to do things that were not possible before, one nice thing about Haiku is that, being developed by a single team, interface changes like this can be done more easily than in a composite system. On Linux you would have to maybe change some FreeDesktop spec, and then get it implemented in every file management app. In Haiku, you don’t have that type of problem.
I don’t know Tracker and its drag messages well enough to say if there’s a reason it was implemented this way, and if the reason still applies. Maybe changing how Tracker behaves will cause subtle breakage elsewhere. But we can surely find a protocol that makes everyone happy?
I assume tracker took a shortcut here.
However, if this is done with two different applications the first problem still remains. You can’t drag from an application that is closed. Perhaps we need to add a new “drag canceled” state for this.
I’m looking into it to see if I can get a better understanding of the Tracker’s internals and maybe submit a patch.
It suffices to check the existence of the sender upon redragging and throw an error, if I understand you correctly.
Hmm, It would be much better if those items dissapeared with the closing of the app that initiated the drag. Unless you in such a case take over the items and keep them. (would also be an option)
But I’m going to read the source of DropIt and how tracker does it now to give you a more comprehensive answer
It depends, if the Drag message is part of a negotiated drag and drop maybe, but I would avoid having the items disappear even with a warning.
The recipient should be responsible of checking this situation regardless of DropIt.
Even more so that the Negotiation and Data messages do not go through DropIt!, they will be regularly exchanged between the two applications.
If it’s not negotiated, for example a colour being dropped, it does not matter if the sender quits in the meantime.
No expert here, but isn’t that what you can do with PonpokoDiff, drag 2 files onto the icon? (lesson learned from @humdinger ) :slight_smile:
EDIT: strike that :slight_smile: read that in reverse :rofl:
I have done a minimal patch for the Tracker I will submit soon. I just need to test it thoroughly so let’s see if it is acceptable.
I have decided to fix only the problem I described in #19368 because changing the whole logic in Tracker looks too invasive. For what regards DropIt! the sensible course of action is to preprocess the message, strip out the relevant fields and add more to simulate a foreign drag conforming to what the Tracker expects in this case.
I’d like you to keep in mind that trackers code came directly from BeOS, unlike most parts of the system. If there is something beeing done wrong in tracker it’s usually not because we think this is great design, but rather that we haven’t gotten around to cleaning this up yet.
I think tracker should behave in this just like every other applications, and you should not have to hack around it in your application.
(That implies however that for negotiated drag&drop it still can’t work because moving from app a to app b while app a is closed doesn’t work either. Maybe we can have a “gimme all options you have” option to make this kind of handoff work when an application is about to close)
Edit: especially your scenario B in your ticket is something, that while unlikely, would hugely confuse a user when this happens accidentally. Probably realizing only later that something wrong/or partially, was dragged to a usb drive for example
Even for negotiated drop messages it is possible to ask for all available formats and save them while origin application is running.
