As my subject states, does Intel based BeOS applications supposed to run unmodified under Haiku?
Are all downloadable applications on Haikuware Haiku only apps or are there BeOS apps also.
TJ
TJ
Some Beos r4 and r5 Intell apps work, some do not do to bits and piece of code and close API’s that are not well documented.
Haikuware has beos and Haiku specific apps. There are lots of comments on the apps that do and do not work.
Have fun.
