Dear BeOS (& Haiku) Community,
Does anyone know if if these Audio & MIDI specs can currently be done with BeOS (will Haiku?):
My focus for using BeOS, besides as a general purpose desktop OS, is for Audio & MIDI purposes. As such, I am looking for the highest Sample-Rate and Bit-Depth supported and tested Audio hardware with BeOS R5. My Audio ideal would be 3 Channels of simultaneous Recording and 2 Channels of simultaneous Playback at a minimum sample rate of 192 kHz and bit depth of 24 bits. Ideally, I would be using (outboard) external A/D and D/A converters, so what I really am after is a Digital I/O (RCA/Coax S/PDIF or AES/EBU) Audio solution which can handle what I am looking for…Does anyone know who makes hardware that there are tested drivers for which will work at that sample rate and bit depth; also what software applications would I have to use which would support recording and playing back at that sample rate & bit depth?
Does anyone happen to know if the Digital Audio I/O works properly under BeOS R5 and/or Zeta 1.21 or 1.5 on the Gina 3G and Layla 3G at 96-kHz, 24 bits when using Jerome’s Echo Audio Driver?
For MIDI, does anyone know which brand and model of a tested interface provides the least amount of jitter for external MIDI Recording and Playback with BeOS R5?
Thank you.
Sincerely,
ultimatesynth
e-mail: supersynth@earthlink.net
