I’m sure at one point I could boot Haiku on this setup, but it may have been before I moved over to using an NVME M2 drive. On recently nightlies (and the first beta 3 test image) I can’t get this machine to boot at all - selecting a bunch of safe mode options (safe mode, safe gfx driver, disabling everything) means I can get the icons to sit on screen with none highlighting, choosing nothing but debug output causes an instant reboot when I hit “continue booting”. I’ve not found any combination of settings that’ll show any of the on-screen debug output. Not sure where to go from here, any thoughts?
This it probably some failure in boot loader at loading kernel/drivers/settings before kernel is started. Boot splash is stored and displayed by boot loader.
Is there a way to do a ‘debug’ build of the boot loader?
It is possible to enable debug tracing in boot loader by changing #ifdef
's in source code.
BIOS version of boot loader has some crash debug output, UEFI may display some crash information.
I’m on UEFI - will see if I can roll a build sometime!
