With the upcoming switch to WebKit2,we’ll finally have the chance to make use of WebKits built-in adblocking feature.
Ads and tracking scripts consume a huge part of the network traffic,so being able to filter them out will already save you a good part of your network consumption.
Anything else you suggest would require extension support,which WebPositive doesn’t have yet and I’m not sure if it will ever be available,since it’s a huge amount of work.
Personally I’d really like having LocalCDN,always using it in LibreWolf,but expect to wait some years until it’s available in WebPositive,if at all.
Quite frankly, if you have limited internet connectivity, use any other browser. Like epiphany or iceweasel.
WebPositive features no caching, which means every ressource your site needs will be requested every single time in it’s entirety… this is obviously quite bad for your internet usage, especially if metered.
WebKit already supports webextensions itself. It’s probably possible to activate and use this stuff… personally I’d rather not open this can of worms, especially not know when there are much bigger things to worry about for webpositive
fwiw WebPosittive uses the actual system colors per default on websites… So unless your website overwrites these (which pretty much all of them do) you can read with your OS colors
thats not what i meant by reader mode. what i meant is that the webpage is turned into a simple document with no css or js. links does this pretty well
Yes,WebKit supports WebExtensions,but integrating them into the browser and making them work seems to be a non-trivial task.
As far as I know,Safari is still the only WebKit-based browser with full WebExtension support.
GNOME Web added support a few years ago,but it seems that is still experimental.
I just tried,had to install Dconf Editor to edit a hidden config value (set org.gnome.Epiphany.web.enable-webextensions to true) so that I can finally install a extension,and then the one I tried didn’t really work (LibRedirect - the extension popup opens very small and empty,unusable).
I’d very much like to have extensions supported in WebPositive some day,but realistically that will take some years,if even the GNOME developers with bigger manpower need that long.
I also agree that having reader mode would be nice,but it won’t have any effect on data usage as the page is usually fully loaded first,and then you enable reader mode to remove the non-relevant parts from it.
