Cvs co
I have been trying to checkout code to learn more about the kernel and it seems anonymous isnt working or doesnt have the permissions to do so. Whats an easy way to download the source?
hm, anonymous cvs should work, but if it’s not (sourceforge has cvs issues every once in a while)
maybe try the cvs browser, it lets you download the source files too
http://cvs.sourceforge.net/viewcvs.py/open-beos/
if you’re using scripts to download it or have edited your .profile to put a CVSROOT in there … you will most likely have to update it.
About a month or so ago, SF changed the address for CVS servers.
Those new details can be found here.
HTH
AhHa!! Gotit! THanks guys. Just had to change a few things in cygwin and got it working :).
