Creating efi boot partition after installation
hello everyone. i installed haiku on my hard drive a week ago and it has been nice to use. however i think i have a major issue
when installing haiku i completely forgot to create an efi partition, even though im on an efi system. this means i cannot boot haiku unless i go into the boot menu of the pc.
now technically haiku and everything works, but it is really annoying to press f12 every time i want to open haiku. is there a way to add haiku to the uefi boot options after installation? i do have legacy boot but no mbr. and i tried to create an efi partition but it didnt work. help me thank yo
If you used the full size of your hard drive to install Haiku,you can’t add a EFI partition afterwards since you can’t resize/shrink Haikus BFS partition.
Support for resizing BFS partitions is work in progress and not yet complete.
But if your computer supports legacy boot and offers that in the F12 menu,there should also be a way to make that the default,so that you don’t need a EFI partition.
Did you check your boot order in the BIOS?
Your hard disk without UEFI should be first.
Also,legacy boot/CSM must be enabled,but since you can boot Haiku from the F12 menu,it likely already is.
i have legacy boot yes and i managed to fix the problem on my own
basically i went into the boot menu and selected legacy boot instead of uefi. and then i made my ssd first in the boot order, and now it automatically boots. so this is a solution, but it requires legacy boot so not
possible on newest pcs. still thanks for help
Ahoy !
If you have an option to add another drive into your system or already there is,
then you can add an ESP partiton on that another drive.
In that case you can copy the ESP partiton content of your installer drive, but that EFI config contains the EFI bootloader in the default directory, so that ESP boots Haiku automatically by EFI boot. It’s logical as it configured to boot the installer Haiku that contains the installer image. With manually you can reconfigure as you want, you just have to decide - if you have other OSes too installed on that system - which would you like to boot as per default. That bootloader should be put into that drive’s /EFI/BOOT/ directory, and others should be placed into another directories like /EFI/‘your OS’/, and discover/set it with your UEFI BIOS to be able to boot - all of them.
Also option to learn reFind that can be copied and configured in your newly created ESP partition. The addition is you can have fancy OS icons and OS names to boot with, selecting from a list as well.
It requires learning the config on that ESP partiton.
That amazing is - that you can do it from Haiku.
→ Drivesetup is capable to create ESP partiion.
→ You can mount it, and now FAT support is safe again
to use file operations there from Haiku. In the time of
Beta5 - even on Nightly - there were a period when
there were issues with FAT file operations - the copy
resulted in 0 bytes files. It’s problematic if you would
like to update the EFI bootloader, or even first copy
there.
But now - all is OK to do it from Haiku. :slight_smile:
:cowboy_hat_face:
