This is a simple PHP script that uses FPDF to make CD and DVD covers on A4/Letter sheets (at the moment).
It’s not yet finished (of course), btw basic functions such as background resizing/positioning and cut&bend lines drawings works.
Check it out:
<a href=http://www.forart.it/covergen/cover.php?pagina=A4&copertina=DVD&remoto=http://www.beos.tarman.pl/grafika/konkurs1/skwarna_haiku7.jpg>http://www.forart.it/covergen/cover.php?pagina=A4&copertina=DVD&remoto=http://www.beos.tarman.pl/grafika/konkurs1/skwarna_haiku7.jpg
Parameters explaination:
- pagina - means the sheet type (A4 or Letter);
- copertina - means the cover type (CD or DVD);
- remoto - is the absolute path of the image you wanna use;
Note that the script is still in alpha stage, so many functions are not yet implemented (different images for front and rear sides) or will change.
Feedbacks are - of course - welcomed.
Last but not least, the script is CC BY-NC-SA licensed, so source code is available, if you need.
Hope that helps, or at least inspires !
