Thank you Jonathan McCormack for contributing your Dell Precision T1500 to the list! It should now be listed on the Haiku Computer List page and on GitHub.
Please note pull or edit requests will be ignored.
To add new hardware:
Method 1: The easiest way is to use the Add Hardware form (v3) powered by Google Forms. Method 2 : If you don’t like Google, you can alternatively add your hardware by posting to or replying to this thread (but if you do it this way, please refer to and use the same format the other hardware listings do with the template). The listing will then be posted on the Hardware List as with Method 1.
Please do not create edit or pull requests on Sheets or GitHub, as these will be ignored.
For any fixes or questions, please post them here, and I’ll update the hardware list when I can.
Sometimes I can be a few days late in getting these up; sorry for the delays. Thank you to everyone who contributes hardware to this list! Hopefully it does help the community as Haiku gets ever closer to Beta 2
Thank you to the anonymous contributor for your hardware contribution; as selected in the form, this entry is not listed on the hardware list repo on GitHub.
Please note pull or edit requests will be ignored!
Though it’s been mentioned before, please do not send edit requests to the spreadsheet. I’ve got several of these recently, and I cannot grant access as it may allow someone to change previous entries by other users, so, again, if you want to add hardware to the list, please either:
Copy the manual template and paste your hardware into a reply below
Or… just post your hardware here casually (example: “Hi, I have a 2007 MacBook with a 2 GHz Intel Core 2 Duo processor and 2 GB of RAM with Haiku Nightly hrev54042 on it I started from a DVD. Starts and runs normally, though I get no sound”)
But please, as I’ve mentioned before, please do not send edit requests to the sheet as I won’t respond to these. Thank you.
Please note pull or edit requests will be ignored !
Method 1: The easiest way is to use the Add Hardware form (v3) powered by Google Forms. Method 2 : If you don’t like Google, you can alternatively add your hardware by posting to or replying to this thread (but if you do it this way, please refer to and use the same format the other hardware listings do with the template). The listing will then be posted on the Hardware List as with Method 1. Method 3 : Or… you can also simply reply to this thread with a useful description of your hardware (example: “Hi, I have a 2007 MacBook with a 2 GHz Intel Core 2 Duo processor and 2 GB of RAM with Haiku Nightly hrev54042 on it I started from a DVD. Starts and runs normally, though I get no sound”)
Please do not create edit or pull requests on Google Sheets or GitHub, as these will be ignored.
Thank you to Thomas and pat74 for your contributions to the hardware list! (Also, for the Inspiron 7573, the CPU has been added in from the spec sheet).
Surface 2 Pro with 4GB RAM and 128GB SSD. Boots to part way with default settings.
So, I was trying to find a computer that would run 64bit Haiku natively, and gave my Surface 2 pro a go. I actually got a lot farther than I assumed. It booted to the Haiku boot screen and all of the icons lit as if it was going to work. However, at the point it should have started the desktop, the screen went black. But the DVD carried on loading then stopped. I clicked the “return” button on the keyboard and I guess it activated whatever the default action is next, as the DVD span up again and began loading something else (live CD/boot to desktop?). I’m going to try booting again later and try some of the safe mode options - but has anyone else successfully got one of these to boot to a usable system before? I used the Nightly hrev54088 if that helps. If I can get the screen to work, I guess it might be usable (though I don’t know if the Surface coder will work.)
Sadly, I don’t have a powered hub and running the DVD and a keyboard at the same time was drawing too much power, so I couldn’t get in to the boot menu to change the options. I’ll see if I can make it happen with an SD card or thumb drive when I get a chance.
You can also edit the kernel settings file (home/config/settings/kernel/drivers/kernel and force vesa mode there. This can be done from another computer before booting on this one.
Thank you memsom and jma_sp for your contributions! I’ve organized your hardware info into the listing format and have added it to the ‘Haiku Computer List’ page. If you would also like your info on the GitHub repo, let me know
Thank you also to CHale for your mobile workstation contribution; it’s been added here, to the page, and to haiku-computer-list on GitHub.
Method 1: The easiest way is to use the Add Hardware form (v3) powered by Google Forms. Method 2 : If you don’t like Google, you can alternatively add your hardware by posting to or replying to this thread (but if you do it this way, please refer to and use the same format the other hardware listings do with the template). The listing will then be posted on the Hardware List as with Method 1. Method 3 : Or… you can also simply reply to this thread with a useful description of your hardware (for example: “Hi, I have a 2020 Leafbook with a 2.6 GHz Intel i7 9750H processor, Intel HD graphics, and 8 GB of 2666MHz DDR4 RAM with Haiku Nightly hrev54042 on it and I started from a USB drive. Works fairly well. Can connect to the Internet including over WiFi. Starts and runs normally, though I get no sound.”)
As part of preliminary hardware testing with Haiku, I’ve went ahead and tested a few Macs with Haiku which I’ll also be showing in the ‘Haiku on Mac’ thread
Hello. I just submitted a form for my HP DC5800. Afterwards, I went to go look at the compatability list on github. At the following link at line 68, there’s a false entry credited under my name(TheJooomes, my channel name). I didn’t file this. The computer in the linked youtube video is the HP DC5800 that I just recently filed a legitemate form for, and the entry at line 68 on github has lots of incorrect information. I’m assuming that someone watched the video and tried to guess the specs and model of the computer so they could file a hardware compatibility form on my behalf. Since a lot of the information in the entry at line 68 is incorrect, can it be removed please?
