CD installation?
Id like to install Haiku on an older laptop. It cant boot from USB, nor does it have a DVD drive, just a CD drive.
Is there a way to install from a CD?
I think that the nightly images still fit in a CD… if that’s the case, you could install one of those, and then either use that, or switch to the beta4 “channel” if you want.
You can get the nightlies from here: https://download.haiku-os.org/
C/dvd rw rdives are really cheep, especially if you know someone with an old used computer.
yeah you can get a USB DVD drive from Amazon for less than $25 US. I got one to finally rip all my music CDs to mp3 and it worked great.
The OP has a laptop, unless it has a drive bay module (I’ve got a DVDRW in a PIII Dell that remained compatible with much newer modules); they won’t be able to replace it with a DVD drive.
some laptops just use normal SATA connectors inside so you could extend these out - but most of these have DVD drives!
They’ve also said it doesn’t do USB boot which will include USB DVD drives - they’re the same protocol.
So its nightly image or nothing… however, I’d wonder whether the laptop is new enough to really run Haiku anyway? Modern browsers need SSE2 for instance and I don’t think there’s many P4/AthlonXP era machines with just CD.
Hi!
I vaguely remember there beeing software you can burn on cd’s to then have it boot iff the usb drive via the software on the cd… Don’t have a name for you but it may be an option if your system cant do usb boot
Yes, plop boot manager might get you out of this situation by booting from USB even if the BIOS doesn’t support it:
https://www.plop.at/en/bootmanager/download.html
