The tutorial for building Haiku on Ubuntu is still quite relevant. It can be found here. That’s assuming you are using or would be willing to switch to Ubuntu.
I’m currently building Haiku on Ubuntu 9.04 beta (Jaunty Jackalope). The only thing I can think of that’s missing is the YASM requirement. You can get it by running: sudo apt-get install yasm. Then you just need to re-run the ./configure command to update.
Edit Better yet… you should be able to get yasm by simply adding it to the initial sudo apt-get install command.
I got the very same problem, and don’t know how to deal with it,…I’m glad that someone able to answered here, and share information, this might be a big help…thanks!!!
