Cannot create BFS partition on GPT drive
I made some room on a Hackintosh drive (GPT drive) for 2 FAT32 partitions (as placeholders). I booted up the latest Haiku Nightly off of a USB pen drive. I went to the GPT drive (with DriveSetup) and can see the 2 FAT partitions. I tried selecting either one and could not reformat either one with a BFS file system. DriveSetup said both were read-only.
Is it not possible to make them writable so they can be reformatted? I tried to bring up GPARTED off of a CD but could not find any way to mark them as writable. In Windows 7, same thing.
Anyone run into this problem before?
https://dev.haiku-os.org/ticket/8823
I hope you din’t mount them?
Right, DriveSetup won’t let you format a mounted drive. The menu option is disabled.
If you unmount those drives can you then format them?
When I un-mount the partitions, I cannot format them. DriveSetup says that they are read-only.
That’s okay. The GPT issues seem to be well-known at this stage so they’ll probably get fixed.
In the meantime, it’s not all that bad to use Virtual Box instead of going native.
WARNING WILL ROBINSON: GPT + OLD-BIOS-SYSTEM = NIGHTMARE
