The hardware has Debian 9 currently installed, so if there’s any more info you need I can use utils there to collect it. That said, I won’t have access to this HW very often, so if anyone is willing to help debug this, I’d be happy to help but I guess you’d also have to be patient.
I’d like to know if I should file a bug or something…
You can try blacklisting drivers but I don’t see anything obvious.
Maybe try blacklisting all but the VESA driver, blacklist all network drivers and sound etc… stuff that isn’t nessecary to boot and see if it gets any further. Usually if it is something like that though it will hang on the driver init etc… and it will be more obvious which one it is. https://www.haiku-os.org/docs/userguide/en/bootloader.html#troubleshooting
Also there is no “net icon” do you mean the first one? I suspect Haiku just doesn’t work at all with your chipset… probably because one has tested with recent-ish Xeon hardware?
