Try making your image bigger
Create the file build/jam/UserBuildConfig (if not done already)
Add this:
HAIKU_IMAGE_SIZE = 4000 ;
This will generate a 4GB image file, it should be enough, even in debug mode.
Add this:
Yes, it did! I see a haiku-nightly.image generated now ! Thanks ![]()
This rather cryptic error happens when you donāt have yacc/bison installed in your host system. Iām not sure what exactly should check if it is installed (probably binutilsā ./configure?), and why the build doesnāt fail when deffilep.c fails to be generated.
Thanks, this helped me past this error.
Iām trying to build Haiku on Elementary OS, and sudo apt-get install bison solved the missing deffilep.c error.
I also had to install libz (sudo apt-get install libz-dev).
