Summary
The C Framework for OpenCL, cf4ocl , is a cross-platform pure C object-oriented framework for developing and benchmarking OpenCL projects. It aims to:
- Promote the rapid development of OpenCL host programs in C (with support for C++) and avoid the tedious and error-prone boilerplate code usually required.
- Assist in the benchmarking of OpenCL events, such as kernel execution and data transfers. Profiling comes for free with cf4ocl .
- Simplify the analysis of the OpenCL environment and of kernel requirements.
- Allow for all levels of integration with existing OpenCL code: use as much or as few of cf4ocl required for your project, with full access to the underlying OpenCL objects and functions at all times.
Features
- Object-oriented interface to the OpenCL API
- New/destroy functions, no direct memory alloc/free
- Easy (and extensible) device selection
- Simple event dependency mechanism
- User-friendly error management
- OpenCL version and platform independent
- Integrated profiling
- Advanced device query utility
- Offline kernel compiler and linker
Official website: http://fakenmc.github.io/cf4ocl/
Hope that helps or, at least, inspires.
