Tracker’s folder’ icons listing size/mode switcher (list, details, big icon etc)
That explains it, then. I carefully selected my keyboard not to have a Windows key in the first place ![]()
(well, actually, it simply predates that key)
Model M?
Stupid fill up characters
I miss a better structured syslog, sometimes I struggle finding the point between boot and last shutdown.
Also, I would factorize kernel debugging so not every driver has to implement its debugging macros.
6 posts were merged into an existing topic: My progress on supporting modern Trackpads
- Bluetooth support for HID and audio devices
- Support for E and P-cores in the scheduler to properly support newer CPU architectures
- Fixing remaining Wayland compositor issues (e.g. dragging)
- BePDF with support for continious view instead of just per page scrolling
By continous scroll, you mean that each page are layouted in a global vertical (or horizontal) orientation so that the whole PDF document can be scrolled over by one action?
Ahoy @darble ,
You mean you want to select Icon Size in the Listing View mode as well ,
that is available in Icon View already ?
It maybe just an enhancement ticket about Tracker – from you – in
Haiku ticketing system – TRAC
Think about it .. and take your time to open it, if I’m right and you are ready to initiate it -
Kernel fix for running Wine 32-bit on 64-bit Haiku
- BeOS application compatibility on 64-bit Haiku
- Mature and fully merged 3D acceleration
- Intel 4500MHD GPU driver
One thing I would really like to see is an easier way to insert accented characters into documents. Like how macOS you can hold a key down and select which one you want.
Unless there’s already an easy way to do this that I don’t about?
Installer which installs on a full SSD or HDD Haiku and Windows with reFind automatical and working!
Format, Partitionig and install for use with Windows or from within Windows 11
- USB devices hotplug (USB sound cards, USB WiFi etc.)
- DELETE key alternative on keyboards with no DELETE key (I’m looking at my MacBook Pro)
- working “Print to PDF” ( Making sure you're not a bot! )
+1 nephele: Multiprocess webkit
+1 egrath: BePDF with support for continious view instead of just per page scrolling
Hi,
Usb audio, bluetooth headset support, Intel hda hdmi Support on my old laptop msi gp60 2qf.
Regards lorglas
Sound Blaster Play! 3 USB sound card works for me! ![]()
eMMC (as already mentioned) for some older/cheaper devices would be nice. I’d also like to see suspend/hibernate (if possible) as it’d make laptop use far more viable for me.
You can probably edit your keymap and move the delete character wherever you want it. Either by drag and drop in the keymap preferences or manually editing the keymap file.
Thank you! I will try it.
The default video player and some of the default applications it comes with could use a little touch up and some more bug fixes for those
