Best supported mini-pcie wifi card?
I haven’t been using my netbook much with haiku because the wifi doesn’t work. I was wondering if someone can suggest an alternative wifi card that is known to be rock solid?
On my other laptop the wifi works but is a little unreliable, so I don’t want to use that chipset.
Thanks, I’ll get one of those :slight_smile:
http://www.intel.eu/content/www/eu/en/wireless-products/centrino-advanced-n-6235.html?_ga=1.153533688.1510571094.1446708677
device 088e: Centrino Advanced-N 6235
Work fine.
