Hi, any idea where i can find some audio drivers to try and get sound working. None listed on HaikuDepot.
Btw, I LOVE HaikuDepot. soo much easier than bebits.
On 32 bit you can install opensound from Depot.
To complete the reply: all other drivers are bundled with Haiku. So if neither the default drivers nor opensound work, you are out of luck and someone has to fix or write a driver for your machine.
Thanks Pulk,
is there a post/info somewhere with the supported chipsets for sound?
