Ahoy @VoloDroid ,
If you read my post carefully I’written that ARM64 Haiku porting effort / development happens under virtualization – however that VM is running on an M1 Max Apple Silicon. So not directly - right now.
Well, for EFI is supported or not on Apple Silicon - I do not know.
However this ARM64 port - rolling over by Owen - can target general ARM64 install, so I mean any 64 bit ARM SoC or motherboard which ones has potentially newer - so UEFI - firmware ..
Also I had not dove deep into ARM64 boot possibilities, so I had not discovered/investigated previously all the exact firmwares and loaders - this way I just wrote earlier what I’ve red on Gerrit’ log tab - under hrev57994 :
hrev57994
arm64: Fix cache enable/disable during bootload
- Fix crash in arch_mmu_generate_post_efi_page_tables due to MMU being disabled too early. Fixed by only disabling the cache/MMU while TTBRx is being written.
- Disable I-cache while TTBRx is being written. This mirrors the
behavior in u-boot.
- With these fixes, UEFI boot now reaches ExitBootServices before crashing.
Of course I was not really precise as the fixes improvements targeted memory related - loader and OS - functions .. what I could shell out from the notes/remarks given to the patch (look above)..
By the way, additional , memory management patches were merged
Commit message (Expand) Author Age Lines
* arm64: Clean up memory GetMemoryAttr.hrev58028 Owen Anderson 19 hours -24/+45
* arm64: Full implementation of MakeTable Owen Anderson 19 hours -36/+42
* arm64: Implement address space switching Owen Anderson 19 hours -5/+111
* arm64: Implement translation map freeing Owen Anderson 19 hours -16/+54
* arm64: Create an empty page table for use
as a placeholder page table. Owen Anderson 19 hours -0/+30
* arm64: Fix translation map setup.hrev58017 Owen Anderson 3 days -8/+19
* arm64: Fix physical page memcpy operations.hrev58012 Owen Anderson 5 days -10/+14
* kernel/arm64: Give bitfield padding fields names.hrev58009 Augustin Cavalier 5 days -41/+41
* arm64: Small fixes extracted from larger MMU fixup.hrev58005 Owen Anderson 6 days -0/+8
* arm64: Remember to switch address spaces on context switch. Owen Anderson 6 days -0/+2
* arm64: Disable timer when not in use.hrev58003 Owen Anderson 6 days -6/+9
* kernel/arm64: Use virtual rather than physical timers. Owen Anderson 6 days -7/+10
So .. development is under progress in a VM actually, I assume Owen has deep knowledge of ARM environment ( if you read the comments in the code
… sorry I may not understand C++, but english : yes .. and I never denied - I’m a curious person, of a kind of eccentric
Also seems provided patches are systematically connects each other.
May @tqh, or @pulkomandy, who committed more patches ..
or at least @waddlesplash - in the next monthly report -
will reveal more precisely what happens actually –
aaaand what most interesting for us …
Till which stages the boot process is reaching with these latest development efforts ?
Anyway,
soon end of month …
there will be a lot to include in the next report …
→ R1B5 may finalized until then
→ ARM64 port is beeing progressed
→ there are PPC cross build efforts
→ May Risc-V goes into (Haiku way) standardized and will be starting to work on to fit into Haiku regular infrastructure ?
( finally at least building downloadable - nightly or snapshot - images, as for x86 architectures - I can imagine a lot to resolve till it appears on Haiku download page)
Exciting times right now !..
EDIT :
fixed typos and “erased” parts of sentences
by my palm and the touchpad
