Apache web server, is cgi-bin enabled and where is cgi-bin
I’ve been looking into apache on Haiku, I see it is in haikuports.
I ran pkgman install apache
I ran hp apache and got a copy of the build.
I checked and ran the .recipe and it (the cgi-bin directory) seems to be at
/boot/system/data/apache/cgi-bin
The httpd.conf file says the same.
But is cgi-bin enabled? And the directory above is in a Read only file system.
So how to add a cgi-bin script? And will Apache run it?
It’s quite possible that that part of the port recipe pre-dates Haiku’s switch to read-only system.
It’s easy to define cgi-bin’s location in the Apache config file though, which should work for you?
It does not matter to me where cgi-bin goes. I leave the location to the main developers who have a better handle on where things should go. Just let me know where.
Should I submit a ticket at the haikuports wiki about this? To get the Apache port modified?
