t do nott tundertstantd
why so hard to interpret
or
how some people reads and understand what other writes -
I had wrtitten about 2 different types of docking stations.
I suggested to create new category for old, classical docking stations, thats more than just a simple port replicators like USB or USB-C connected new type of “docking stations”.
I’m happy I could learn some USB “docking station” has power button as well … but can you detach it without handle it in OS ?
I mean if you unlock retention mechanism on a classical docking station, and detach laptop without any software clicks, and both the laptop and docking station works longer without problem.,
The laptop can be closed, and when you open the lid then just power up display, and if you attach again everything continues without docking station reconfiguring on OS level…
However, back to USB connected ones.
Such USB devices can be used with such laptops which has no docking ports on the bottom
like all Apple laptops,
or not the workstation grade or not business laptops, which ones also has no specific docking ports.
For example I always laughed when I saw on teBay as
Dell Inspiron 9100 was enlisted as compatible at classical Dell port replicators and docking stations.
Dell Inspiron 9100 had/has a special USB attached "docking USB port" but there were nothing on its bottom as a docking port.
Many seller had not took the fatigue to read carefully how this machine’s “docking” works.
It had a special USB connector which was a power connector as well twhen USB had not contained that generally. Present day it is not unusual the USB port has power feature as well.
However this USB port worked with an outer box, so this docking mechanism served as a limited one device attachehment. It could connect only one device at once. One optical drive or an another floppy drive or an IDE or SCSI disk drive, or a floppy alternative device.
It was not for printer or keyboard, mouse or anything else that is basically default for a port replicator. It cannot handle multi devices - against that it was connected via USB. Possibly as the port could drive one device – related to power. It had not required to use power cable to the device. It was given by the laptop itself via power connectors of this special USB port and the cable that connected to the box which contained the Dell equipped with storage devices/drives.
In Dell terminology in 90s they called it docking station, but it is such marketing nonsense like Starship for Elon’s new rocket and spaceship.
(Ha-ha! Starship !.. it will travel between planets and moos … for long months … NOT between STARS !.. Hilarious !.. )
Anyway, I hope I was clear now, why I suggested classical docking stations as they are different type of hardware than any type of USB connected port replicators and “docking stations”.
Kind regards,
