An idea for a word processor
I was thinking about word processors a lot. Basically, at the moment there are few to none lightweight and productive word processors for people who don’t need the functionality of a full-blown MS Word. Furthermore, there is a problem with formats. There is old RTF which has an open standard, but is not implemented properly even in MS products, the compatibility is still an issue here. There are MS .doc formats which are almost closed and hard to implement. There is OOXML that has an open specification, but a vague and complex one, so implementing it is still hard. And there is ODT, which is open, but is still evolving and doesn’t have a wide adoption yet. Inventing another format may be a bad idea, if it doesn’t rely on existing technologies that can be somehow viewed on most popular OS-es.
So here was my idea for a format. Basically, just use a plain text with a markup done in Markdown (plus some extensions, for footnote support, smartypants, tables, etc), zip it (so that all images used in the document will be stored with the text in a single file). Apply a .text extension, so it can be distinguished.
What’s the point? First, I believe (yeah, I am no coder, but still) that it’s easier to implement the read and write support for a plain text with those tags than it is for any of the existing document formats. You can have two modes in the word processor: the WISYWIG one and something like WordPerfect’s reveal codes mode where the user can adjust the formatting manually (since the markup is really easy here, even easier than in HTML). No XML or anything, so you can actually avoid using heavy technologies which results in a lightweight app.
Then, this markup is pretty flexible. You may add export to (x)HTML and export to PS and PDF options, so a user could actually get the output in a format that is more popular. The fact that Markdown is often used in CMS and blogging engines makes this format easy to integrate in the online publishing solution. You can prepare an article in your desktop app, then easily get it online (there are markdown support plugins for wordpress, for instabce). Finally, when you have to involve somebody into editing this file, you can just send him the .text file, he can unzip it (zip support is available in all major OSes nowadays) and work with the plain text. The markup is humane readable, so chances are, he won’t have any problems here whatsoever. Finally, markdown implementations are available for all major platforms, you just have to be careful about using extensions that are not included into the original Markdown specification and thus are not supported by all implementations.
Markdown sure doesn’t have all the formatting features you can expect from a full-blown word processor like MS Word. But the point here is that such a word processor is not aimed at people who need MS Word. It’s not even for somebody who needs a lot of collaboration in word processing (I believe, there is nothing better than Google Docs for that). It’s for people who need to work content-oriented. Apply some simple formatting that just makes the text readable and its structure clear. Then, get the output in PDF and send it to somebody, who will read (like an editor, for instance. Or a teacher) and is not likely to edit this text. The PDF will be sent (in case with an editor) to somebody who is responsible for formatting it (designers, etc), they will extract the text and disregard your formatting anyways. Or get the output to your blog. Or just get HTML and get it to your homepage. Or publish the PDF there for download. And you have a tool for that. A tool that is fast to start, fast to work, and is stable. Oh, and it’s especially useful for somebody who needs to create a text that will be used by him alone. A lecture note done on a netbook (there is no appropriate word processor for a netbook, actually). Bloggers, students, journalists, writers - those are a target group for such an app.
I was also thinking that it would be cool (as soon as more browsers get HTML5 audio and video tags support) to have the ability to easily get an instant picture, Vorbis voice record or a Theora video to your document using the webcam and mic (especially when we’re talking about a laptop or a netbook). That could be an ideal blogger/podcaster thing, but hard to be used otherwise (you can’t get it to PDF or PS) outside this word processor. It’s something similar to Psion’s Word where you could easily add voice memos to the text without leaving the word processor.
So, what I’m talking about is something more advanced than StyledEdit: a mixture of a word processor and a blogging client. Lightweight and more aimed towards contemporary text processing needs. And since all the technologies here are already existing, there is no reinventing the wheel being done, so one could expect to have some more apps supporting this kind of format on other platforms.
What do you think? I would love it if somebody who is looking for a project idea would like this and try to create something. I cannot code, but I can design the whole interface (I just need to learn the paradigms of BeOS/Haiku interfaces) and provide all the testing (especially the usability) and feedback needed. I believe this kind of app would be a killer-feature for Haiku. I would really most definitely make a switch for such a tool, it doesn’t exist on any platform yet=)
P.S.: sorry for a long post. Thanks to all who have read it.
"funny you should mention’ …lightweight WP apps…
Using StarOffice (and derivatives) since it was still lightweight, one had to adapt to DE menus and pay for it in German Marks - but for sure it has become about as bloated as such things can be. Followed Abiword until it (rather recently) became usable at all, and my current fast to load tool for those .doc files WinSerf’s send me is KWord (yeah - not really a fan of KDE, but it is reasonably light, and seems to work better than AbiWord).
See also ‘SIAG Office Suite’(Scheme In A Grid) for ‘lightweight’. Though not .doc compatible, other lightweight tools (antiword et al) can de-MStify the input.
But the reality is that even in the business world, the complex document/DTP niche has nothing like the hold it once had on the ‘market’. Even MS Word would be withering faster if MS had not tied it into email composition and the like. We are (finally) using fewer trees and more electrons.
Given that more and more ‘traffic’ relies on basic content (SMS, email) and less and less on on-paper fonts and formats, what, then still works ‘well enough’ to preserve the basics:
IMNSHO…
html - (and derivatives).
Plus: More or less human-readable directly, and easily fed through a stripping process to remove tags.
Minus: No absolute guarantee it will be displayed as you intended, as the viewer’s styles can over-ride yours. But ‘close enough’ for most needs.
ps - Yes, Postscript.
Plus: It is both directly printable on many printers, easily converted to hpgl for others, directly editable or convertible to such with lightweight tools, and easily converted back and forth to .pdf as well.
Not to forget that .pdf is about as good as ‘cross-platform’ gets with regard to preserving intended appearance.
Nearly all WP out there can generate .ps OR .pdf simply by print-to-file selection in the printer subsystem, even if they lack internal ‘export’ capability.
Minus: Not human-readable, even for an old Forth coder…
Last, but not least … LaTex remains surprisingly effective for output format control relative to either the ‘weight’ of its editing & processing tools or the size of its stored files.
:wink:
So I’m not seeing the need for yet-another mark [up|down|sideways] ‘specification’ while there are so many cross-platform tools already available to manipulate the three above.
In this case (file formats) ‘older is better’ because older was leaner. And most bugs and limitations have long since been dealt with.
JM2CW, but I’d be tempted to build on the SIAG/Pathetic Writer concept, even if not written in Scheme.
All it might need is a set of failry ‘lean’ add-ons to Haiku’s existing ‘pe’ editor.
Somone would first have to port the markdown engine. Txt2tags works on Haiku now - all you have to do is change the first line to tell it where to find python. I’m actually planning a t2t manager. create your t2t file in any text editor, then use the manager to convert to a variety of formats. Waiting for T2T version 3, though.
I think also the txt2tags format would be much better than the markdown one: beside the fact the txt2tags syntax is way cooler than the markdown one, because of the macro system in txt2tags you can easily extend it to almost everything you can think of (footnotes for example).
txt2tags 3 will have footnotes built in (for target formats that support it), and RTF and ODT support. See http://code.google.com/p/txt2tags/w/list
Of course, it’s still a one-way street. There is AFAIK no “XXX to Txt2tags” utility. So the question of what to do with the Word document that someone sent you remains.
My favorite word processor was the last version of WordPro before it was integrated into Lotus SmartSuite. It did everything I wanted it to; while still being very fast. After it’s integration with SmartSuite it got too complex and too slow. I used to teach both WordPro and MS Word. WordPro was better in every way. A WordPro document with the same text was a fraction of the size of the Word version.
koffice is running in Haiku now (I haven’t tested yet though):
http://tiltos.com/drupal/node/17
