As you might have noticed, the WiFi encryption bounty ends tomorrow. Obviously, this is a good time to give an overview over what I did in the past weeks. Unfortunately, and hopefully before I got you excited, the most interesting thing of the bounty, the wpa_supplicant, does not work yet. I've ported it to Haiku, but so far it has resisted my attempts to find out where the problem is located -- well, in the hours I put into debugging I've found a couple of potential causes, but there is at least one more to be found, and fixed.
This is a companion discussion topic for the original entry at https://www.haiku-os.org/blog/axeld/2010-12-14_almost_not_there_yet/
