About gsoc
heyy i got few general questions on gsoc
  1. what are the typical number of contributions i need to make to standout ?? yes number of contributions do not matter !! what matters is how i interacted with people and how quality bugs did i actually contribute but usually every year what are the typical number contributions these gsoc selected people make?
i would love to learn from any kind of advice from the community. The problem is this is my first time ever getting into open-source so everything feels messy and too many doubts
if this is your first time in open source i recommend you start with linux or BSD simply because they are more used so its easier to find help
anyway if you want to stand out then i recommend you do this. install haiku on your pc and use it to see what you think is missing. for example, there is no native sftp client. i think you should install on an older computer. not too old but around 2015 is the sweet spot if you will.
you should also read up more on open source. so read wikipedia. if you dont have experience with linux try it out first to familiarise yourself with open source software, again try on an older computer.
also you from india?
typically i have seen some low level contributions like drivers. you can also do higher level things by studying c/c++ and the BeAPI
yesss i am from india and i am a student in computer science from a tier-3 college :smiling_face_with_tear:
indian engineer starter pack lol. im also indian but im not engineering, i learnt my knowledge from using the computers itself. i recommend you do that since college books wont teach so much
true i learned my c++ from learncpp.com and now trying to have a good understanding on oops concepts in c++ with cherno c++ series and before that i have learned c from harvard’s CS50 course so it not only make me learn a language but also made me interested into low level things but the people here are talking in a weird language like drivers, ports , something with bluetooths, wifi so it feels very hard to even understand what they are speaking
these all are common terms in computer science. basically wifi is internet, bluetooth is how a wireless connection works, ports are either the ports on the computer that are used to connect things like pendrive keyboard mouse or ports on networking which is a number. and drivers are programmes that allow you to use different hardware, like wifi driver allows you to use wifi. on haiku, linux they are built in but on windows you have to install them manually
since you are from a tier 3 college i will give you the benefit of doubt. however if you are serious about gsoc then you must learn what these things mean on your own. no one else here is from india, so they dont know how tier 3 colleges are. they will not show mercy. learn these common computer science terms by searching on internet. good luck
thanks for all the info and time you took to explain things. yeah i know the literal meanings of what wifi, bluetooth and ports are but not as good as they are discussing but thanks for the knowledge i’ll keep learning things
Not a GSoC mentor here, but have been a mentor for years on the GCI program, pointing students to BSD/Linux is IMHO not the place to do here, plenty of resources out there if students are interested in the GSoC program.
@Sathwik-88 some links to get you on your yourney could include:
  • Install and get familiar with Haiku
  • Find things that annoy you and try to fix them and send patches in for review to gerrit
Some useful links:
I don’t quite understand this? The question was about Haiku. I think for working with Haiku you are much better suited to work on some haiku tickets?
Anyway the complexity to contribute is much lower in Haiku than in linux, we have one sourcetree and one bug tracker.
ssh is preinstalled…
This reads as incredibly rude to me… What is the point of this sentence?
Don’t worry too much :slight_smile:
Just start with some tickets marked as “(easy)” on the bugtracker, or try to fix something that annoys you personally. If you push something to the review tracker developers (such as I) will review your patch and give you pointers if something can be improved. Nobody will be mad at a “bad” patch.
If you find something hard to understand you can ask for clarification :slight_smile: sadly we do not have a glossary for these kinds of things.
But here is a start:
Driver: a software component typically provided by the Operating system that powers a specific piece of hardware; for example for audio output you need a audio driver
ports: This is either (per context)
  1. A software that was build for another OS, like linux but brought over to Haiku
  2. A mechanism for different applications and services in Haiku to communicate with each other
bluetooth:
This is a wireless radio protocoll used for devices to communicate with each other
wifi: this is also a wireless radio protocoll for devices to communicate with each other (sometimes also called wlan); but with differen throughput and latency properties as bluetooth.
This is utter nonsense. We don’t require or demand that someone has studied computer science before contributing here. You can send a patch with whatever knowledge level you have, the only requirement is that you ask if something is unclear to you, and answer questions if a reviewer is unclear to why you did something a certain way. Maybe the reviewer knows a better way, maybe the reviewer can learn something from you. Aproach this with an open mind and we can arrive at nice solutions.
(EDIT: for gsoc itself you may need a bit of knowledge to be picked… but even then it has to be knowledge in that area… you don’t need intimiate knowledge of cpu design to do a project with UI design for example)
what i am trying to say is that this person shouldnt expect everyone here to hand hold them. they did not know some basic terms so i warned them on what would happen if they did not know. you and me and this community may be nice, but what happens after college? or when going to a serious open source project?
i asked them to first try linux and BSD because they said they had not much experience in open source software
and i told ‘indian engineer starter pack’ because thats very common over here. parents will ask you to study for iit (basically mit) by doing jee (basically gaokao). its extremely hard to enter iit so most go for lower colleges, called tier 2 and tier 3 colleges. almost every other person does this. my parents even asked me to do it before i dropped out of science. i meant it more as a joke, not an insult
So you’re saying it’s easier to create a patch for a Terminal (example) in Linux/BSD then it is in Haiku, and you can learn more from that and get more help from their community instead of ours?
Maybe your comment is done with the best intention, but IMHO our of place here.
The level of knowledge for any student starting is the same no matter what OS the students want to target, we target Haiku here.
Sorry if my comments sound a bit harsh, but I do have a history with working with students, and the idea is to give them all a good learning experience, no matter of the starting level of knowledge.
Atleast in my circle “something starter pack” is usually an insult.
Nothing will happen. The worst outcome as that OP will just, learn something…? Learning from each other is not “hand holding”. And this is certainly not a space where each request for clarification will be answered by “just ask the internet” or more modern “ask your keyboard text prediction”.
And it does not matter, this is already one of larger open source projects… if you want to claim that it isn’t “serious” enough because it’s not toxic enough I would be really confused what open source projects you encountered.
Linux is a gigantic corporate backed project. I would even go so far as calling it the biggest open source project. I don’t think this is a great place to start if you want to get your feet wet(linux, the kernel I mean), so to speak. If you care more about servers than desktops the BSDs are fine aswell, but I doubt BSD or Haiku are any less or more acomodating for people with less experience.
Anyway, experience is gained. You can’t expect that someone is born with the knowledge to contribute to open source. Open source has to be open to people who do not know everything, otherwise there is no way for people to actually become contributors and no way for it to survive, it will just become a club of old people eventually then.
Nothing wrong there? :rofl: (back to topic) *
Example: Google Summer of Code
One - This is mentor or lead developer(s) directional. Also, standout to whom/who (i.e. Haiku/school/etc)? There is a list of the GSoC projects important to Haiku.
Also, top tier-3. Schools give you community, resources, organization, and core foundation. There is also student discounts. Use that to your advantage on getting access for the things you need for your projects.
Oh… life lesson… a cool-headed pleasant demeanor can win over technical acuity. Make friends and prosper…
Quality bugs… or bugs of quality…
Ref:
https://review.haiku-os.org/q/status:open+-is:wip
The forum is good, but use Haiku’s IRC for reaching out to certain people (see: mentor).
Certain devs are reachable through the bug tracker if you work on bugs or enhancements.
Start with a small project (or whatever your mentor suggests). No need to get grey hair on your first run. Just listen, take orders, enjoy the work, and focus on completing your assignments.
Oh, and bring snacks for everyone…
thanks for handing me all the resources genuinely happy for that
yess i did that mistake by starting directly into LLVM compiler infrastructure it was very tough to even get a response for beginner questions and i am really happy that you guys are always responsive even for the beginner things
i would say standout to the community it would also be nice if i could get into gsoc but my answer would be to the community
