3C905B support
On BeOS my 3C905 Card is not recognized. It works in Linux and Syllable.
I did try to put it into PCI slot 1 and 3 and 4.
instead of ec9xx driver I did try the 3c920 driver. No Use.
Tried Bone. Did not help.
Is there a source code available for this device driver (Ex ec9xx) so that I maybe can see what is the problem.
Yes. It is a 3C905B Card. (OR rather probably a 3C950-Combo) This is the outpot from my messgae log file starting up Linux:
3c59x: Donald Becker and others. www.scyld.com/network/vortex.html
0000:00:0f.0:
3Com PCI 3c905B Cyclone 10/100/BNC at 0x1000. Vers LK1.1.19
I run BEOS PE 5
Somewhere I read that the BEOS driver works only if the card is on IRQ 5.
Mine on linux is put to IRQ 10.
Actually I read on the 3COM support that with the PCI card one can only change the IRQ settings by moving it into a different PCI slot. Maybe on my DELL computer I do not hit the right IRQ.
BeOS or Haiku? I never had a problem with my 3C905b card in BeOS 4 or 5.
Ditto, I’ve never had problems with my 3C905b… I’ve also never had problems with my 3c905c card at home - but my one 3c905c-tx card on my previous workstation at work did NOT properly work in R5 or BONE. Apparently they changed something on the chipset that prevents the built-in driver from working any longer with those cards.
Perhaps 3com pulled a stunt like ATI does and change the PCI ID number of a card while keeping the same model number. I remember getting an ATI Rage Fury Pro that was on the R5 hardware list but wasn’t recognized. It took a slightly hacked driver to recongize the card. Maybe this is the case here?
yeh I’ve had exactly the same issue as umccullough has had …
DarkWyrm wrote:
Perhaps 3com pulled a stunt like ATI does and change the PCI ID number of a card while keeping the same model number. I remember getting an ATI Rage Fury Pro that was on the R5 hardware list but wasn't recognized. It took a slightly hacked driver to recongize the card. Maybe this is the case here?
No, it was even more sinister.
The card was recognized by BeOS, and appeared to be working - but generated absolutely no traffic whatsoever… DHCP failed, ICMP failed, etc.
