So I’m new to json and yaml but from everything I’ve read, I’m guessing the json format would look like this (for mobile workstations tested with R1/Beta2 so far):
"MobileWorkstations": [
"Model" : "HP Pavillion dv5000 (Intel Centrino Duo + Geforce 7400 Gpu)",
"Rating" : "2/4 - Haiku needs extra options to start and/or barely works",
"Version" : "Haiku R1/Beta2 (latest stable release)",
"Architecture" : "32-bit x86 (i686, etc.)",
"Share_on_GitHub" : "Yes",
"Startup_media" : "USB storage media (using Legacy/USB 2), Standard SSD, hybrid SSHD, or hard drive (imaged or installed)",
"Startup_mode" : "(U)EFI, by choice (32-bit)",
"RAM" : "3GB available cause of 32bits (Total 4GB)",
"CPU" : "Intel Centrino Duo (Geniune Intel T2400) 1,83Ghz",
"GPU" : "Nvidia Geforce Go 7400",
"Networking_cards" : "Ethernet Intel Pro 100 + Intel Wireless 3945AGB",
"Sound_cards" : "Conexant HD Audio (chipset)",
"Boot_options" : "Blacklisted entries, Disabled APM, Disabled ACPI",
"Graphics_status" : "Graphics work, by default or out of the box",
"Sound_status" : "Sound works, but by using OpenSound, etc",
"Networking_status" : "Ethernet card(s) work",
"SD_status" : "My computer does not have a SD drive",
"Restart_status" : "Haiku restarts with special options",
"Input_status" : "Trackpad and keyboard both work",
"Power_status" : "Haiku detects the battery and shows charge time correctly",
"Cam_status" : "My computer does not have a webcam, etc.",
"Contribution_date" : "7/17/2020 13:04:28",
"Contributor" : "Kitsune64"
"Model" : "Origin EON15-X",
"Rating" : "3/4 - Haiku works with most of the components",
"Architecture" : "64-bit x86 (Intel x64/AMD64, etc.)",
"Startup_media" : "NVMe/PCI Express drive or a M.2 drive (imaged or installed)",
"Startup_mode" : "(U)EFI, by choice (64-bit)",
"RAM" : "32 GB",
"CPU" : "AMD Ryzen 9 3950X (16-Core, 32-Thread)",
"GPU" : "NVIDIA GeForce RTX 2070 8GB",
"Networking_cards" : "Intel Wi-Fi 6 AX200",
"Sound_cards" : "Realtek High-Definition Audio",
"Boot_options" : "Used fail-safe graphics driver",
"Graphics_status" : "Graphics work, but in Safe Graphics mode or Vesa",
"Networking_status" : "Both Ethernet and WiFi cards work",
"SD_status" : "SD drive works with Haiku",
"Restart_status" : "Haiku restarts smoothly",
"Power_status" : "Haiku does NOT detect the battery",
"Cam_status" : "Cameras do not work with Haiku on this computer",
"Contribution_date" : "7/9/2020 14:22:21",
"Contributor" : "RLeonhardt"
If I have this right, I’ll begin converting the current (beta2) files from plain text to the new format
